Zum Hauptinhalt wechseln
HP Pavilion 15-cs3xxx Battery Replacement
Was du brauchst
  1. HP Pavilion 15-cs3xxx Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 15-cs3xxx Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power off and unplug the laptop from any power source.
    • Flip the laptop over so the bottom is facing up.
    • Prior to removing the two screws near the hinge, remove the two rubber feet with a spudger or opening tool.
    • Two of the five screws are under the rubber feet nearest the hinges.
    • Use a Phillips screwdriver to remove the five screws on the underside of the laptop.
  2. HP Pavilion 15-cs3xxx Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-cs3xxx Battery Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool and picks to carefully pry off the back cover.
    • Work your way around the perimeter and release the clips holding the case to the device.
    • Carefully remove the back case.
  3. HP Pavilion 15-cs3xxx Battery Replacement: Schritt 3, Bild 1 von 1
    • Locate the battery which should be a large rectangular component located at the corner of the laptop.
    • Use a screwdriver to remove the four screws holding the battery in place.
  4. HP Pavilion 15-cs3xxx Battery Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the battery from the chassis.
    • Install the new battery and repeat the process to secure it.
Abschluss
Following these steps in reverse order to reassemble your device
5 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 36
Letzte 30 Tage: 154
Insgesamt: 4,408
