Einleitung
This guide will help you be able to take out and replace the Hard drive in the HP Pavilion 15-d017cl. A hard disk drive is a non-volatile memory hardware device that permanently stores and retrieves data on a computer. This guide requires a Phillips #1 screwdriver, spudger, tweezers, and an iFixit opening tool.
Was du brauchst
Flip the laptop onto its back in order to have access to the back "L" shaped panel.
Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
To remove the L-shaped panel, use the plastic opening tool to pry the panel from the back of the laptop. Make sure to move the tool the entire way around the panel.
Using the opener tools, pry around the edges of the computer in between the keyboard and the base.
Flip the keyboard up toward the screen to access the motherboard.
Using the Spudger, press into the silver latch and lift it up.
Using the Tweezers, pull the Ribbon Cable out of the silver latch.
Using a Phillips #1 screwdriver, remove the three screws located around the hard drive.
When finished unscrewing, pull the hard drive out.
4 weitere Personen haben diese Anleitung absolviert.
