Einleitung
This guide will walk through the steps to replace the Motherboard of the HP Pavilion 15-d017cl. The Motherboard allows communication and power throughout the computer through accessing memory and CPU. This guide requires a Phillips #1 screwdriver, spudger, tweezers, and an iFixit opening tool.
Was du brauchst
To unlock the top left latch, place your finger on the black latch and slide toward the center of the computer.
To unlock the top right latch, slide the black latch towards the center of the computer.
Flip the laptop onto its back in order to have access to the back panel.
Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
To remove the L-shaped panel, use the plastic opening tool to pry the panel from the back of the laptop. Make sure to move the tool the entire way around the panel.
Using a spudger, press down on the silver latches that are holding the RAM in place. The RAM looks like a blue rectangle and has a size of about 1 x 2 inches. A slight click will be heard, and the RAM should pop out. You can then pull it away from the laptop.
Detach the connected chord with your fingers from the motherboard.
Remove the fifteen (15) 5mm screws using the Phillips #1 Screwdriver from the case.
Remove the second attached cord at the top of the removed panel.
Using the Spudger, lift the latch to unlock the ribbon cable.
Using the Tweezers, pull the ribbon cable out of the latch.
To the left of the RAM, pull up on the black tab to disconnect it from the motherboard.
Using the opener tools, pry around the edges of the computer in between the keyboard and the base.
Flip the keyboard up toward the screen to access the motherboard.
Using the Spudger, press into the silver latch and lift it up.
Using the Tweezers, pull the Ribbon Cable out of the silver latch.
Using the Spudger, lift up on the silver latch until the Ribbon Cable is unlocked.
Use the Tweezers to pull the Ribbon Cable out of the latch.
Using the Spudger, press into the silver latch and lift it up to unlock the latch.
Use the Tweezers to pull the Ribbon Cable away from the latch.
Remove the ten (10) 5 mm screws with the Phillips #1 Screwdriver on the Motherboard until the Motherboard loosens.
Lift the tight side of the Motherboard and flip it toward the cooling fan showing the back of the Motherboard.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
