Was du brauchst
Switch the first lock, with the padlock icon, to the open position.
Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
Begin by laying the laptop on its backside with the bottom of the laptop facing you.
There will be 11, 2.5x3.0mm Philips head screws that you will need to locate.
Continue by unscrewing all of them using a 0 Phillips screwdriver.
Take off the back panel by removing the 4.0x4.7mm Philips head screw.
Then using the opening tool, work around the edges to pull off the back panel.
Now flip the computer right side up and open up the laptop.
You should be facing the screen and keyboard.
Now using the opening tool remove the front panel from the back panel.
It should start to pop off, you will have to do this step around the entire computer.
Once you have popped off the panel it should simply be able to lift off of the laptop.
Keep in mind that the keyboard is still connected to the motherboard. Simply lay the keyboard on top of the screen while you are completing future guides.
You can replace the front panel now.
There will be two screws (4.0x4.7mm) that need to be removed so lift the Hub away from the computer.
Next disconnect the flat cable by pulling the cable straight out of the connector from the USB Hub.
