Einleitung
This guide will show you how to completely remove the HP Pavilion 15-eg0025nr back panel. The back panel is on the underside of the laptop and protects many of the laptop's internal components.
Removing the back panel allows you to access many internal parts of the HP Pavilion 15-eg0025nr that are necessary for most repairs or replacements, such as the battery or fan.
Before attempting to remove the back panel, unplug the laptop and turn it off.
Was du brauchst
Flip over the computer so that the back panel is facing upwards.
Remove the two silver screws on the bottom of the laptop using a Phillips #00 screwdriver.
Peel up each end of the two gray rubber stoppers using your fingers or an opening pick.
Remove the two black screws underneath the rubber stoppers with the Phillips #00 screwdriver
Slide the opening pick around the edges of the laptop where the chassis has a seam.
2 weitere Personen haben diese Anleitung absolviert.
