Zum Hauptinhalt wechseln
HP Pavilion 15-eg0025nr Screen Replacement
Was du brauchst
  1. HP Pavilion 15-eg0025nr Screen Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Unplug and turn off the laptop before removing the back panel
    • Flip over the computer so that the back panel is facing upwards.
    • Remove the two silver screws on the bottom of the laptop using a Phillips #00 screwdriver.
  2. HP Pavilion 15-eg0025nr Screen Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 2, Bild 2 von 2
    • Peel up each end of the two gray rubber stoppers using your fingers or an opening pick.
    • This may be difficult if it is your first time removing them.
    • Remove the two black screws underneath the rubber stoppers with the Phillips #00 screwdriver
  3. HP Pavilion 15-eg0025nr Screen Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 3, Bild 3 von 3
    • Slide the opening pick around the edges of the laptop where the chassis has a seam.
    • You will hear a clicking noise as you undo the clips of the chassis.
    • It may be easier to start with the four corners of the laptop, and then follow through with the sides.
  4. HP Pavilion 15-eg0025nr Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the back panel completely.
    • With the back panel removed, you can now access parts of the laptop such as the fan or the battery.
  5. HP Pavilion 15-eg0025nr Screen Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove the five screws from the battery using a Phillips #00 screwdriver.
  6. HP Pavilion 15-eg0025nr Screen Replacement: Schritt 6, Bild 1 von 2 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the battery from the laptop.
  7. HP Pavilion 15-eg0025nr Screen Replacement, Screen: Schritt 7, Bild 1 von 3 HP Pavilion 15-eg0025nr Screen Replacement, Screen: Schritt 7, Bild 2 von 3 HP Pavilion 15-eg0025nr Screen Replacement, Screen: Schritt 7, Bild 3 von 3
    • Do not attempt to remove the screen without first removing the back panel and battery. Ensure that the laptop is powered off before removing the screen
    • Find the hinge bezel where the display bezel meets the back panel.
    • Using an opening pick, unclip the hinge bezel by sliding the pick along the hinge.
  8. HP Pavilion 15-eg0025nr Screen Replacement: Schritt 8, Bild 1 von 3 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 8, Bild 2 von 3 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 8, Bild 3 von 3
    • Using an opening pick, pry open the top, sides, and bottom of the display bezel.
    • Remove the display bezel and set aside.
  9. HP Pavilion 15-eg0025nr Screen Replacement: Schritt 9, Bild 1 von 3 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 9, Bild 2 von 3 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 9, Bild 3 von 3
    • Remove the six golden screws with a Phillips #00 screwdriver and set aside.
    • There are three screws on each side.
  10. HP Pavilion 15-eg0025nr Screen Replacement: Schritt 10, Bild 1 von 2 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 10, Bild 2 von 2
    • Remove the two silver screws at the top of the display panel with a Phillips #00 screwdriver.
  11. HP Pavilion 15-eg0025nr Screen Replacement: Schritt 11, Bild 1 von 3 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 11, Bild 2 von 3 HP Pavilion 15-eg0025nr Screen Replacement: Schritt 11, Bild 3 von 3
    • Using an opening pick, carefully pry the screen from top, sides, and bottom of the display panel.
    • Be cautious to not bend or snap the screen as you pry it out.
    • Remove the screen and set aside.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 49
Insgesamt: 1,332
