Zum Hauptinhalt wechseln
HP Pavilion 15-n210dx Hard Drive Replacement
Was du brauchst
  1. HP Pavilion 15-n210dx Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over.
  2. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Push the pins towards each other using your thumbs. The battery will pop out a little bit. Remove it using your hand.
  3. HP Pavilion 15-n210dx Hard Drive Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
  4. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Open the laptop and use a spudger gently to get under the keyboard. Loosen the keyboard on all sides and then lift it up.
  5. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Use the spudger to unhinge the fastener and remove the connector.
    • The keyboard should be completely detached from the computer now.
  6. HP Pavilion 15-n210dx Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Use the Tri-point Y0 screwdriver to remove all screws on the metal sheet, then remove the metal sheet.
  7. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the two blue wire connectors using the reverse tweezers and lift up on the two wires to disconnect them.
  8. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the twelve (12) screws from the back panel.
  9. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 9, Bild 1 von 2 HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Remove the optic drive by pushing the edge with your thumbs to open it. Once open use two hands to remove it entirely.
  10. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Remove the screws that become exposed after removing the optic drive using a Phillips #0 screwdriver.
  11. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 11, Bild 1 von 2 HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 11, Bild 2 von 2
    • Wedge the metal spudger between the black and silver plastic.
    • Slide the spudger along the edge of the laptop to help in ease of separation. Next use your hands to separate the black plastic from the silver plastic.
    • Avoid using the metal spudger unless it's for serious prying power. If used incorrectly, the metal spudger can damage the internal components of the device.
  12. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 12, Bild 1 von 3 HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 12, Bild 2 von 3 HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 12, Bild 3 von 3
    • Remove the two connectors that are attached to the hard drive by lifting up and away from the connected port.
  13. HP Pavilion 15-n210dx Hard Drive Replacement: Schritt 13, Bild 1 von 1
    • Remove the hard drive by lifting up on the back side of it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Seth Shea
222 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 3-8, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G8
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 1,169
