Einleitung
This guide will aid in replacement of the hard drive in an HP Pavilion 15-n232nr. The process is fairly time consuming due to keyboard removal. Screwdriver, plastic opener, metal spudger, and tweezers are the necessary tools.
Was du brauchst
Slide the battery locks towards the center of the laptop. The battery will detach automatically.
Remove the battery by sliding it away from the laptop housing.
Flip the keyboard out and locate the connector.
Use the spudger to unhinge the the fastener and remove the connector.
Use the iFixit opening tool to slide the optical drive away from the laptop housing.
Remove the ten 6 mm Phillips #1 screws.
Remove the three 1 mm Phillips #000 screws.
Use the spudger to unhinge the daughterboard connector.
Remove daughterboard connector.
Use the iFixit opening tool to remove the hard drive connector.
Remove the hard drive by lifting the right side and pulling it out.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
How to test it's processor
