Was du brauchst
After removing all the 8 mm screws, start to pry open the optical drive using your finders or a wedge.
Pull out the battery by positioning the switch with the lock symbol on unlock and pushing the switch with the battery towards the center of the laptop.
Use an opening pick or wedge to start to pry open the laptop keyboard cover.
Follow along the perimeter and separate the cover from the laptop.
Locate and remove the screw holding the I/O board in.
Once the screw has been removed lift the I/O board straight up and out of the case.
Eine weitere Person hat diese Anleitung absolviert.
