Zum Hauptinhalt wechseln
HP Pavilion 15-p043cl Repair Optical Drive Replacement
Was du brauchst
  1. HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 2 HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: Schritt 1, Bild 2 von 2
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair Optical Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-p043cl Repair Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair Optical Drive Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 15-p043cl Repair Optical Drive Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 15-p043cl Repair Optical Drive Replacement: Schritt 3, Bild 3 von 3
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 98
