Zum Hauptinhalt wechseln
HP Pavilion 15-p214dx Disk Drive Replacement
Was du brauchst
  1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: Schritt 1, Bild 1 von 3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: Schritt 1, Bild 2 von 3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: Schritt 1, Bild 3 von 3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Disk Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-p214dx Disk Drive Replacement: Schritt 2, Bild 2 von 2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
Abschluss
Patrick Seaver
1.001 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S2-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 251
