Zum Hauptinhalt wechseln
HP Pavilion 15-p214dx Display Replacement
Was du brauchst
  1. HP Pavilion 15-p214dx Display Replacement, Disk Drive: Schritt 1, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement, Disk Drive: Schritt 1, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement, Disk Drive: Schritt 1, Bild 3 von 3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Display Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-p214dx Display Replacement: Schritt 2, Bild 2 von 2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
  3. HP Pavilion 15-p214dx Display Replacement, Top Cover: Schritt 3, Bild 1 von 1
    • Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
  4. HP Pavilion 15-p214dx Display Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-p214dx Display Replacement: Schritt 4, Bild 2 von 2
    • Remove the 5.5mm screws holding the computer's end caps in place. The end caps are located to the left and right of the battery.
    • These screws are normally hidden underneath the end caps' rubber feet, which are not shown in the pictures. To remove these, gently pry them out of their slots with a plastic opening tool or a flathead screwdriver.
  5. HP Pavilion 15-p214dx Display Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 5, Bild 3 von 3
    • Lift both end caps from their respective corners.
    • Use a Philips #0 screwdriver to remove the 4.3mm screw that is underneath both end caps.
  6. HP Pavilion 15-p214dx Display Replacement: Schritt 6, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 6, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 6, Bild 3 von 3
    • Use a Philips #0 screwdriver to remove the three 5.5mm screws in on the edge of the disk drive slot.
    • These three screws are missing from the pictures.
  7. HP Pavilion 15-p214dx Display Replacement: Schritt 7, Bild 1 von 1
    • Flip your computer so that the bottom is now on the surface. Open the laptop like you normally would if you were about to use it.
    • Use a plastic opening tool to separate the top cover from the bottom cover.
    • Be careful when prying the cover off since it is susceptible to bending and cracking.
    • There are several cables connecting the top cover to the computer's motherboard that need to be disconnected before the cover can be completely removed.
  8. HP Pavilion 15-p214dx Display Replacement: Schritt 8, Bild 1 von 2 HP Pavilion 15-p214dx Display Replacement: Schritt 8, Bild 2 von 2
    • While lifting the top cover, undo the clip holding the keyboard cable in place.
    • Slide the cable out of its port.
  9. HP Pavilion 15-p214dx Display Replacement: Schritt 9, Bild 1 von 1
    • Undo the clip holding the touchpad cable in place.
    • Remove the touchpad cable from its port.
  10. HP Pavilion 15-p214dx Display Replacement: Schritt 10, Bild 1 von 2 HP Pavilion 15-p214dx Display Replacement: Schritt 10, Bild 2 von 2
    • Undo the clip holding the power button cable in place.
    • Disconnect the power button cable from its port.
    • Gently lift the top cover to remove it from the computer.
  11. HP Pavilion 15-p214dx Display Replacement, Motherboard: Schritt 11, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement, Motherboard: Schritt 11, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement, Motherboard: Schritt 11, Bild 3 von 3
    • Notice that the motherboard is connected to multiple components of the computer that need to be disconnected first
  12. HP Pavilion 15-p214dx Display Replacement: Schritt 12, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 12, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 12, Bild 3 von 3
    • Use a plastic opening tool to separate the speaker's cable from the mother board, by pushing on the speaker's plugged cable
  13. HP Pavilion 15-p214dx Display Replacement: Schritt 13, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 13, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 13, Bild 3 von 3
    • Dismount the power supply cable holding the motherboard, by removing the 5.5 mm screws shown in the first picture on the right, using a Philips #0 screwdriver to remove the screws.
  14. HP Pavilion 15-p214dx Display Replacement: Schritt 14, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 14, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 14, Bild 3 von 3
    • Remove the metal cover to free the motherboard supply cable.
  15. HP Pavilion 15-p214dx Display Replacement: Schritt 15, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 15, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 15, Bild 3 von 3
    • Undo the clip holding the display cable.
    • Gently remove and disconnect the display cable.
  16. HP Pavilion 15-p214dx Display Replacement: Schritt 16, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 16, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 16, Bild 3 von 3
    • Disconnect the disc drive cable by undoing the clip.
    • Repeat the same step for the the hard drive cable.
    • Note there is no need to completely remove the hard drive, just undoing the cable from the motherboard should be sufficient.
  17. HP Pavilion 15-p214dx Display Replacement: Schritt 17, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 17, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 17, Bild 3 von 3
    • Remove the 7mm screws holding the computer's motherboard in place.
    • Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's motherboard corners.
  18. HP Pavilion 15-p214dx Display Replacement: Schritt 18, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 18, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 18, Bild 3 von 3
    • After the motherboard is dismounted and all the cable are disconnected, remove the motherboard from the device.
  19. HP Pavilion 15-p214dx Display Replacement, Display: Schritt 19, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement, Display: Schritt 19, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement, Display: Schritt 19, Bild 3 von 3
    • Dismount the display corners by removing the labeled 5.5 mm screws on the corners using a Philips #0 screwdriver to remove the screws.
  20. HP Pavilion 15-p214dx Display Replacement: Schritt 20, Bild 1 von 2 HP Pavilion 15-p214dx Display Replacement: Schritt 20, Bild 2 von 2
    • Notice after removing the screws the screen become able to move easily.
  21. HP Pavilion 15-p214dx Display Replacement: Schritt 21, Bild 1 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 21, Bild 2 von 3 HP Pavilion 15-p214dx Display Replacement: Schritt 21, Bild 3 von 3
    • Line up with the side of the laptop.
    • Push the hinges from left to right to unhook it from it's place.
    • Remove the screen from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Patrick Seaver
1.001 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S2-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 1,065
