Zum Hauptinhalt wechseln
HP Pavilion 17 TS Rear Cover Replacement
Was du brauchst
  1. HP Pavilion 17 TS Rear Cover Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion 17 TS Rear Cover Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion 17 TS Rear Cover Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: Schritt 2, Bild 1 von 3 HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: Schritt 2, Bild 2 von 3 HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: Schritt 2, Bild 3 von 3
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
Abschluss
Sean Croft
739 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Miles Spring 2016 Mitglied von UMass Dartmouth, Team 1-6, Miles Spring 2016
UMASSD-MILES-S16S1G6
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 443
