Einleitung
In this guide it will show you how to carefully replace the RAM. While doing this, remember to use caution when pulling of the back plate, as well as use caution when pressing gently on the RAM. Using too much force could cause the pieces to break off.
Using your hands, push the two tabs inwards to release the battery.
Remove the battery from the device.
Remove eleven screws from the back panel.
Remove the back panel from the device.
Push the two metal clips outwards to release the RAM.
Remove the RAM stick from the device.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
