Einleitung
Before attempting to remove the battery from the HP Pavilion 17-e117dx, make sure that it is powered off and nothing is plugged into the laptop. Also, make sure your hands are clean and dry. You will not need any tools for this procedure.
Slide the battery release latch to the left. The battery will pop up slightly.
Lift the battery upwards and out of the laptop.
Ein Kommentar
Tienes el num de parte de la batería que me digas por favor, gracias
