Zum Hauptinhalt wechseln
HP Pavilion 17-e117dx Hard Drive Replacement
Was du brauchst
  1. HP Pavilion 17-e117dx Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: Schritt 3, Bild 1 von 2 HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: Schritt 3, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 3 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: Schritt 6, Bild 2 von 3 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: Schritt 6, Bild 3 von 3
    • Remove the two Phillips 2.5 x 5.75 mm screws that hold the hard drive down to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 7, Bild 1 von 3 HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 7, Bild 2 von 3 HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the hard drive connector cable from the computer's system board.
  8. HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 8, Bild 1 von 2 HP Pavilion 17-e117dx Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Lift the hard drive out of the hard drive bay by lifting up from the tab.
    • Remove the hard drive from the computer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Marcel Amazan
576 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G5, Bailey Spring 2019
UMASSD-BAILEY-S19S8G5
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 31
Insgesamt: 1,657
