Einleitung
The service panel needs to be removed to access internal components of the HP Pavilion 17-e117dx, such as the hard drive and memory module.
Was du brauchst
Slide the battery release latch to the left. The battery will pop up slightly.
Lift the battery upwards and out of the laptop.
Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
Fast fertig!
Abschluss
