Zum Hauptinhalt wechseln
HP Pavilion 17-e117dx WLAN Module Replacement
Was du brauchst
  1. HP Pavilion 17-e117dx WLAN Module Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx WLAN Module Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 17-e117dx WLAN Module Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: Schritt 3, Bild 1 von 2 HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: Schritt 3, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx WLAN Module Replacement: Schritt 4, Bild 1 von 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx WLAN Module Replacement: Schritt 5, Bild 1 von 1
    • Remove the service panel.
  6. HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: Schritt 6, Bild 1 von 3 HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: Schritt 6, Bild 2 von 3 HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: Schritt 6, Bild 3 von 3
    • Remove the two antenna cables from the top of the WLAN module by pulling them upwards.
    • Be gentle when removing the cables. You don't want to damage them.
  7. HP Pavilion 17-e117dx WLAN Module Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 17-e117dx WLAN Module Replacement: Schritt 7, Bild 2 von 2
    • Remove the single Phillips PM 2.5 x 3.25 screw so that you can remove the WLAN module from the system board.
    • Use the Phillips #00 screwdriver.
  8. HP Pavilion 17-e117dx WLAN Module Replacement: Schritt 8, Bild 1 von 1
    • To remove the WLAN module, pull it away from the slot at an angle.
Abschluss
Marcel Amazan
576 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G5, Bailey Spring 2019
UMASSD-BAILEY-S19S8G5
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 397
