Einleitung
The front panel is removed to access the inner components and is a precursor to RAM, hard drive, keyboard, and screen repair. It is difficult to do because the front panel is very firmly secured and will require a lot of time, strength, and patience to remove.
Was du brauchst
Pull the battery out towards you while your fingers are still holding the latches in place.
Remove the thin plastic cover using the flat metal spudger to expose another screw.
Remove one 7 mm screw with a Phillips #0 screwdriver.
Underneath each rubber foot, there is a screw.
Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
Remove the following six screws with a Phillips #1 screwdriver:
Two 7 mm screws.
Two 7 mm screws.
Two 4.8 mm screws.
Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
Remove the ribbon connecting the keyboard to the motherboard.
You may now fully lift the front panel from the rest of the laptop.
Eine weitere Person hat diese Anleitung absolviert.
