Zum Hauptinhalt wechseln
HP Pavilion 17-f004dx Hard Drive Replacement
Was du brauchst
  1. HP Pavilion 17-f004dx Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
    Frag FixBot
  3. HP Pavilion 17-f004dx Hard Drive Replacement, CD Drive: Schritt 3, Bild 1 von 1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
    Frag FixBot
  4. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Use a metal spudger to push the CD drive out of its slot for removal.
    Frag FixBot
  5. HP Pavilion 17-f004dx Hard Drive Replacement, Front Panel: Schritt 5, Bild 1 von 1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
    Frag FixBot
  6. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 6, Bild 1 von 2 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
    Frag FixBot
  7. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
    Frag FixBot
  8. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
    Frag FixBot
  9. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
    Frag FixBot
  10. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
    Frag FixBot
  11. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 11, Bild 1 von 1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
    Frag FixBot
  12. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 12, Bild 1 von 2 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 12, Bild 2 von 2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
    Frag FixBot
  13. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 13, Bild 1 von 1
    • Partially lift the top cover from the enclosure.
    Frag FixBot
  14. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 14, Bild 1 von 2 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 14, Bild 2 von 2
    • Remove the ribbon connecting the power button to the motherboard.
    Frag FixBot
  15. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 15, Bild 1 von 2 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 15, Bild 2 von 2
    • Remove the ribbon connecting the mousepad to the motherboard.
    Frag FixBot
  16. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 16, Bild 1 von 2 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 16, Bild 2 von 2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
    Frag FixBot
  17. HP Pavilion 17-f004dx Hard Drive Replacement, Hard Drive: Schritt 17, Bild 1 von 1
    • Lift the black retaining bar that holds down the two hard drive ribbons to unlock them.
    Frag FixBot
  18. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 18, Bild 1 von 1
    • Gently pull the ribbons out.
    Frag FixBot
  19. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 19, Bild 1 von 1
    • Lift the hard drive out from the enclosure.
    Frag FixBot
  20. HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 20, Bild 1 von 3 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 20, Bild 2 von 3 HP Pavilion 17-f004dx Hard Drive Replacement: Schritt 20, Bild 3 von 3
    • Pull the rubber casing away from the hard drive.
    Frag FixBot
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
UC Davis, Team 1-4, Oliver Fall 2016 Mitglied von UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 Mitglieder
8 Anleitungen geschrieben
2 Kommentare zur Anleitung
Thank you. Couldn’t figure out why those end caps wouldn’t budge. Dang hidden screws! Kudos!
Shaun Krug - Antwort Teilen
Greet thank to you ! This tuto was very helpfull for me !
Sambat - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 41
Insgesamt: 6,971
