Zum Hauptinhalt wechseln
HP Pavilion 17-f004dx RAM Replacement
Was du brauchst
  1. HP Pavilion 17-f004dx RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Pavilion 17-f004dx RAM Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
    Frag FixBot
  3. HP Pavilion 17-f004dx RAM Replacement, CD Drive: Schritt 3, Bild 1 von 1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
    Frag FixBot
  4. HP Pavilion 17-f004dx RAM Replacement: Schritt 4, Bild 1 von 3 HP Pavilion 17-f004dx RAM Replacement: Schritt 4, Bild 2 von 3 HP Pavilion 17-f004dx RAM Replacement: Schritt 4, Bild 3 von 3
    • Use a metal spudger to push the CD drive out of its slot for removal.
    Frag FixBot
  5. HP Pavilion 17-f004dx RAM Replacement, Front Panel: Schritt 5, Bild 1 von 1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
    Frag FixBot
  6. HP Pavilion 17-f004dx RAM Replacement: Schritt 6, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 6, Bild 2 von 2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
    Frag FixBot
  7. HP Pavilion 17-f004dx RAM Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 7, Bild 2 von 2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
    Frag FixBot
  8. HP Pavilion 17-f004dx RAM Replacement: Schritt 8, Bild 1 von 1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
    Frag FixBot
  9. HP Pavilion 17-f004dx RAM Replacement: Schritt 9, Bild 1 von 1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
    Frag FixBot
  10. HP Pavilion 17-f004dx RAM Replacement: Schritt 10, Bild 1 von 1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
    Frag FixBot
  11. HP Pavilion 17-f004dx RAM Replacement: Schritt 11, Bild 1 von 1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
    Frag FixBot
  12. HP Pavilion 17-f004dx RAM Replacement: Schritt 12, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 12, Bild 2 von 2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
    Frag FixBot
  13. HP Pavilion 17-f004dx RAM Replacement: Schritt 13, Bild 1 von 1
    • Partially lift the top cover from the enclosure.
    Frag FixBot
  14. HP Pavilion 17-f004dx RAM Replacement: Schritt 14, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 14, Bild 2 von 2
    • Remove the ribbon connecting the power button to the motherboard.
    Frag FixBot
  15. HP Pavilion 17-f004dx RAM Replacement: Schritt 15, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 15, Bild 2 von 2
    • Remove the ribbon connecting the mousepad to the motherboard.
    Frag FixBot
  16. HP Pavilion 17-f004dx RAM Replacement: Schritt 16, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 16, Bild 2 von 2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
    Frag FixBot
  17. HP Pavilion 17-f004dx RAM Replacement, RAM: Schritt 17, Bild 1 von 1
    • Remove four 5.6 mm screws with a Phillips 1 screwdriver.
    • Remove one 3 mm screw with a Phillips 1 screwdriver.
    Frag FixBot
  18. HP Pavilion 17-f004dx RAM Replacement: Schritt 18, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 18, Bild 2 von 2
    • Remove the ribbon connecting the optical drive bay to the motherboard.
    Frag FixBot
  19. HP Pavilion 17-f004dx RAM Replacement: Schritt 19, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 19, Bild 2 von 2
    • Remove the ribbon connecting the hard drive to the motherboard.
    Frag FixBot
  20. HP Pavilion 17-f004dx RAM Replacement: Schritt 20, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 20, Bild 2 von 2
    • Disconnect the ribbon from the motherboard that passes over the hard drive.
    Frag FixBot
  21. HP Pavilion 17-f004dx RAM Replacement: Schritt 21, Bild 1 von 2 HP Pavilion 17-f004dx RAM Replacement: Schritt 21, Bild 2 von 2
    • There are still cables between the motherboard and the laptop.
    • Carefully lift the motherboard and lean it against the screen.
    Frag FixBot
  22. HP Pavilion 17-f004dx RAM Replacement: Schritt 22, Bild 1 von 3 HP Pavilion 17-f004dx RAM Replacement: Schritt 22, Bild 2 von 3 HP Pavilion 17-f004dx RAM Replacement: Schritt 22, Bild 3 von 3
    • The motherboard has two slots for the RAM. The process for removing each one is the same
    • Pull the metal tabs away from the RAM.
    Frag FixBot
  23. HP Pavilion 17-f004dx RAM Replacement: Schritt 23, Bild 1 von 1
    • Do not touch the circuits on the RAM. Only hold the RAM by its edges.
    • Gently remove the RAM from its slot.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
UC Davis, Team 1-4, Oliver Fall 2016 Mitglied von UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 42
Insgesamt: 2,263
