Zum Hauptinhalt wechseln
HP Pavilion 17-g119dx Wi-Fi Card Replacement
Was du brauchst
  1. HP Pavilion 17-g119dx Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close your laptop and turn it over so that the bottom is facing up.
  2. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • In the upper left hand corner, slide the bar with the lock icon to the right. This will unlock the battery.
  3. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Slide the bar with the battery icon, on the right of your laptop, to the left to release the battery.
  4. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Grab the battery and remove it from the laptop.
  5. HP Pavilion 17-g119dx Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 1 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 2 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 3 von 3
    • Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
    • Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
  6. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 6, Bild 1 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 6, Bild 2 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 6, Bild 3 von 3
    • Remove the black corner covers on either side of the battery to reveal four additional 6.5mm Phillips #00 screws.
  7. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 7, Bild 1 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 7, Bild 2 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 7, Bild 3 von 3
    • Remove the four 6.5mm Phillips #00 screws that were underneath the black corner covers.
  8. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 8, Bild 1 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 8, Bild 2 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 8, Bild 3 von 3
    • On the right-hand corner of the laptop, remove the CD-ROM by pressing the small button on the side. Pull it out of the laptop, and set it to the side.
  9. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 9, Bild 1 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 9, Bild 2 von 3 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    iFixit Opening Tool
    $1.99
    Kaufen
    • Make sure that all screws and the CD-ROM Drive are removed before trying to complete this step to prevent damaging your laptop. During this step, you will likely hear loud crackling noises. This is normal.
    • Flip the computer back over with the screen facing up and open the laptop.
    • Use the Plastic Opening Tool to separate the face plate from the backing.
  10. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 10, Bild 1 von 2 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 10, Bild 2 von 2
    iFixit Opening Tool
    $1.99
    Kaufen
    • After running the Plastic Opening Tool along the sides, you can gently pop the keyboard open to access the Video Card.
    • The Video Card is located to the left of the fan and below the Processor.
  11. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 11, Bild 1 von 1
    Phillips #00 Screwdriver
    $5.49
    Kaufen
  12. HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 12, Bild 1 von 2 HP Pavilion 17-g119dx Wi-Fi Card Replacement: Schritt 12, Bild 2 von 2
    • After unscrewing the screws, lift the Video Card up from the motherboard. Disconnect the wire from the Video Card by gently wiggling the gold end on the left corner of the card.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kathryn
766 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 496
