Einleitung
This guide will teach you how to remove the back cover of the laptop. This guide will be important for a lot of other replacement guides.
Was du brauchst
Slide the battery lock to the right until you see the open lock symbol.
Remove the fifteen 7mm screws holding the back casing on using the Phillips #00 screwdriver.
Remove the 7mm screw holding the disc drive in place using the Phillips #00 head screwdriver.
Remove the four 7mm screws holding the back resting plates on using the Phillips #00 screwdriver.
Using a metal spudger, lift up on the back resting plate until it pops off.
Pry up on the case with an iFixit opening tool until you can feel a snap.
Pry around the remainder until you can separate the case from the keyboard with your hands.
Gently separate the two.
4 weitere Personen haben diese Anleitung absolviert.
