Zum Hauptinhalt wechseln
HP Pavilion 17-g192dx Disassembly
Was du brauchst
  1. HP Pavilion 17-g192dx Disassembly, Battery: Schritt 1, Bild 1 von 3 HP Pavilion 17-g192dx Disassembly, Battery: Schritt 1, Bild 2 von 3 HP Pavilion 17-g192dx Disassembly, Battery: Schritt 1, Bild 3 von 3
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
    Frag FixBot
  2. HP Pavilion 17-g192dx Disassembly: Schritt 2, Bild 1 von 1
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
    Frag FixBot
  3. HP Pavilion 17-g192dx Disassembly: Schritt 3, Bild 1 von 2 HP Pavilion 17-g192dx Disassembly: Schritt 3, Bild 2 von 2
    • Lift the battery up.
    Frag FixBot
  4. HP Pavilion 17-g192dx Disassembly, laptop: Schritt 4, Bild 1 von 1
    • Using the metal spudger, pry up the screw covers.
    Frag FixBot
  5. HP Pavilion 17-g192dx Disassembly: Schritt 5, Bild 1 von 1
    • Remove the fifteen 7mm screws holding the back casing on using the Phillips #00 screwdriver.
    Frag FixBot
  6. HP Pavilion 17-g192dx Disassembly: Schritt 6, Bild 1 von 2 HP Pavilion 17-g192dx Disassembly: Schritt 6, Bild 2 von 2
    • Remove the 7mm screw holding the disc drive in place using the Phillips #00 head screwdriver.
    Frag FixBot
  7. HP Pavilion 17-g192dx Disassembly: Schritt 7, Bild 1 von 3 HP Pavilion 17-g192dx Disassembly: Schritt 7, Bild 2 von 3 HP Pavilion 17-g192dx Disassembly: Schritt 7, Bild 3 von 3
    • Using an iFixit opening tool, push the disc drive away from the outer case.
    • Once the disk drive is out far enough, it easily slides out.
    Frag FixBot
  8. HP Pavilion 17-g192dx Disassembly: Schritt 8, Bild 1 von 3 HP Pavilion 17-g192dx Disassembly: Schritt 8, Bild 2 von 3 HP Pavilion 17-g192dx Disassembly: Schritt 8, Bild 3 von 3
    • Remove the four 7mm screws holding the back resting plates on using the Phillips #00 screwdriver.
    • Using a metal spudger, lift up on the back resting plate until it pops off.
    Frag FixBot
  9. HP Pavilion 17-g192dx Disassembly: Schritt 9, Bild 1 von 2 HP Pavilion 17-g192dx Disassembly: Schritt 9, Bild 2 von 2
    • Remove the two 7 mm screws behind the plate using a Phillips #00 screwdriver.
    Frag FixBot
  10. HP Pavilion 17-g192dx Disassembly: Schritt 10, Bild 1 von 3 HP Pavilion 17-g192dx Disassembly: Schritt 10, Bild 2 von 3 HP Pavilion 17-g192dx Disassembly: Schritt 10, Bild 3 von 3
    • Pry up on the case with an iFixit opening tool until you can feel a snap.
    • Pry around the remainder until you can separate the case from the keyboard with your hands.
    • Gently separate the two.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 41
Insgesamt: 1,935
