Einleitung
Follow this guide if you need to replace the hard drive of your HP Pavilion 17-x047na.
Was du brauchst
The netbook needs to be top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
Use an ejection pin to eject and remove the CD/DVD drive.
To remove the hard drive, lift both latches to remove the ribbon cable.
Once ribbon cable is removed, use the rubber case surrounding the hard drive to lift upwards and pull the hard drive out.
Eine weitere Person hat diese Anleitung absolviert.
