Zum Hauptinhalt wechseln
HP Pavilion DV2160BR DVD±RW Drive Replacement
Was du brauchst
  1. HP Pavilion DV2160BR DVD±RW Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR DVD±RW Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: Schritt 2, Bild 2 von 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR DVD±RW Drive Replacement, DVD±RW Drive: Schritt 3, Bild 1 von 1
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  4. HP Pavilion DV2160BR DVD±RW Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: Schritt 4, Bild 2 von 2
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  5. HP Pavilion DV2160BR DVD±RW Drive Replacement: Schritt 5, Bild 1 von 1
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  6. HP Pavilion DV2160BR DVD±RW Drive Replacement: Schritt 6, Bild 1 von 1
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 Mitglied von UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G5
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 240
