Zum Hauptinhalt wechseln
HP Pavilion DV2160BR Wifi Adapter Replacement
Was du brauchst
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: Schritt 1, Bild 1 von 2 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: Schritt 1, Bild 2 von 2
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: Schritt 2, Bild 1 von 2 HP Pavilion DV2160BR Wifi Adapter Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: Schritt 3, Bild 1 von 2 HP Pavilion DV2160BR Wifi Adapter Replacement: Schritt 3, Bild 2 von 2
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Shannon
55 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 13-66, Johann Spring 2013 Mitglied von Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 533
