Einleitung
You will be removing the battery. This is a short and simple guide.
Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
The yellow highlighted edge of the battery should pop up slightly when the switch is moved
Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
2 weitere Personen haben diese Anleitung absolviert.
