Zum Hauptinhalt wechseln
HP Pavilion DV3 Hard Drive Replacement
Was du brauchst
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion DV3 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
  4. HP Pavilion DV3 Hard Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion DV3 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
  5. HP Pavilion DV3 Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP Pavilion DV3 Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP Pavilion DV3 Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 14-10, Forte Fall 2013 Mitglied von Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 4,932
