Einleitung
This guide will demonstrate how to remove the hard drive from you laptop. You will need the screwdriver listed in the tools section.
Was du brauchst
Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
The yellow highlighted edge of the battery should pop up slightly when the switch is moved
Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
Put the cover and screw to the.
With your fingers, grab the clear tab.
Pull right first, and then upwards (towards you).
5 weitere Nutzer:innen haben diese Anleitung absolviert.
