Zum Hauptinhalt wechseln
HP Pavilion DV3 RAM Replacement
Was du brauchst
  1. HP Pavilion DV3 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 RAM Replacement: Schritt 2, Bild 1 von 2 HP Pavilion DV3 RAM Replacement: Schritt 2, Bild 2 von 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 RAM Replacement, RAM: Schritt 3, Bild 1 von 3 HP Pavilion DV3 RAM Replacement, RAM: Schritt 3, Bild 2 von 3 HP Pavilion DV3 RAM Replacement, RAM: Schritt 3, Bild 3 von 3
    • Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
    • Both screws will remain attached to the cover.
    • Set the cover with attached screws to the side.
    • The RAM will now be exposed
  4. HP Pavilion DV3 RAM Replacement: Schritt 4, Bild 1 von 3 HP Pavilion DV3 RAM Replacement: Schritt 4, Bild 2 von 3 HP Pavilion DV3 RAM Replacement: Schritt 4, Bild 3 von 3
    • Find the two clips located on each side of the RAM.
    • Using both hands, simultaneously grab each clip and open them away from the RAM stick.
    • The RAM will pop up.
  5. HP Pavilion DV3 RAM Replacement: Schritt 5, Bild 1 von 2 HP Pavilion DV3 RAM Replacement: Schritt 5, Bild 2 von 2
    • Using one hand, pull the RAM up and to the left to remove it.
  6. HP Pavilion DV3 RAM Replacement: Schritt 6, Bild 1 von 1
    • If there is a second RAM module present (as shown), repeat steps 2 and 3 to remove it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 14-10, Forte Fall 2013 Mitglied von Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,980
