Zum Hauptinhalt wechseln
HP Pavilion DV6-6C35DX Hard Drive Replacement
Was du brauchst
  1. HP Pavilion DV6-6C35DX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Flip the laptop so the bottom is facing up.
    • Push the sliding latch to the left to release the battery and remove it from the laptop.
  2. HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Push the same sliding latch to the right to release the L-shaped panel.
    • Remove the panel from the laptop.
    • You may need to use a spudger to pry out the L-shaped panel and release any clips before removing it.
    • When reassembling the device, make sure to start by inserting the bottom of the panel first (see image 3).
  3. HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 3, Bild 1 von 2 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws that secure the hard drive.
  4. HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Lift the hard drive out of the slot from the side under the RAM slot.
    • Be careful not to pull on the cable connecting the hard drive to the laptop.
    • Use a spudger to help lift the drive out of the chassis if you are unable to with your fingers.
  5. HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Pull the plastic ribbon attached to the connector to disconnect hard drive from the laptop.
  6. HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws on the side of the hard drive cage.
    • When removing the screws, hold the drive cage carefully to prevent the hard drive from falling out.
    • Remove the hard drive from the cage.
  7. HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 7, Bild 1 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 7, Bild 2 von 3 HP Pavilion DV6-6C35DX Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the SATA cable from the hard drive.
Abschluss
Jake M.
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 196
