Zum Hauptinhalt wechseln
HP Pavilion DV9700 RAM Replacement
Was du brauchst
  1. HP Pavilion DV9700 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 HP Pavilion DV9700 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: Schritt 2, Bild 1 von 2 HP Pavilion DV9700 RAM Replacement: Schritt 2, Bild 2 von 2
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: Schritt 3, Bild 1 von 3 HP Pavilion DV9700 RAM Replacement: Schritt 3, Bild 2 von 3 HP Pavilion DV9700 RAM Replacement: Schritt 3, Bild 3 von 3
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: Schritt 4, Bild 1 von 3 HP Pavilion DV9700 RAM Replacement: Schritt 4, Bild 2 von 3 HP Pavilion DV9700 RAM Replacement: Schritt 4, Bild 3 von 3
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
Abschluss
Max Shangraw
507 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S6-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S6G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 771
