Zum Hauptinhalt wechseln
HP Pavilion G6-1d16dx Hard Drive Replacement
  1. HP Pavilion G6-1d16dx Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
    • Unscrew the two silver screws holding the protective cover in place.
    • The screws do not detach from the cover.
    • Remove Cover by lifting the edge along the battery compartment.
    • Slide the hard drive towards the empty gap, lift up on the hard drive, and remove it.
    • If the replacement hard drive lacks a rubber case- remove the rubber case that is around the old hard drive, and place it over the new hard drive.
    • Re-insert the hard drive, and slide it back into place.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 98
