Einleitung
If you hear 4 beeps from the computer, it means there is a memory issue. This guide focuses on replacing the RAM in this HP Pavilion. Through 4 easy steps, the RAM can be replaced in a timely manner.
Was du brauchst
Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
Unsnap the cover by lifting the edge along the battery compartment.
Push the two tabs on the sides of the RAM compartment away from the memory stick.
After the tabs are moved, the RAM stick will pop up, and you can pull the card straight out of its slot.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
