Zum Hauptinhalt wechseln
HP Pavilion G60-235DX Keyboard Replacement
Was du brauchst
  1. HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: Schritt 1, Bild 1 von 2 HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Please turn the power of your device off. If not, it may cause a damage to the computer's hard drive and the person.
    • Slide the lock to remove the battery
    • After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
  2. HP Pavilion G60-235DX Keyboard  Replacement: Schritt 2, Bild 1 von 3 HP Pavilion G60-235DX Keyboard  Replacement: Schritt 2, Bild 2 von 3 HP Pavilion G60-235DX Keyboard  Replacement: Schritt 2, Bild 3 von 3
    • Do not force if the frame is not coming out. It may break the clip of the frame.
    • After the screws from battery house are removed, open the laptop to remove the keyboard frame.
    • Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
    • Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
    • Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
  3. HP Pavilion G60-235DX Keyboard  Replacement: Schritt 3, Bild 1 von 1
    • When the frame is removed, keyboard will be free to be removed. There is cable ribbon to be removed. Gently pull out the ribbon from where it is plugged.
    • The keyboard is now detached from the computer.
Abschluss
Gilbert Han
241 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 10-5, Banghart Winter 2017 Mitglied von Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 481
