Einleitung
This will show you how to replace the ram in your G60 laptop.
Was du brauchst
Lay the computer so that the backside is facing you and locate the screw in the picture.
Push this slide over in order to remove the battery. This is safe when working with your computers memory.
Remove each one of the rams so that the computer looks like this. You can do so be squeezing tabs on each side of the ram.
Fast fertig!
Abschluss
