Zum Hauptinhalt wechseln
HP Pavilion G60-630US Hard Drive Replacement
Was du brauchst
  1. HP Pavilion G60-630US Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion G60-630US Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion G60-630US Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion G60-630US Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion G60-630US Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Carefully lift the battery out and away from the laptop.
  3. HP Pavilion G60-630US Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Remove the two 5.5 mm JIS#0 screws from the hard drive cover.
    • Remove cover from the back of the laptop.
  4. HP Pavilion G60-630US Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove three 5.5 mm JIS#0 screws.
  5. HP Pavilion G60-630US Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Gently, slide the whole hard drive to the right with your fingers.
  6. HP Pavilion G60-630US Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP Pavilion G60-630US Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP Pavilion G60-630US Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Lift up on black tap attached to the hard drive to remove the hard drive.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 740
