Zum Hauptinhalt wechseln
HP Pavilion G60-630US Power Button Replacement
Was du brauchst
  1. HP Pavilion G60-630US Power Button Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion G60-630US Power Button Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion G60-630US Power Button Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Power Button Replacement: Schritt 2, Bild 1 von 3 HP Pavilion G60-630US Power Button Replacement: Schritt 2, Bild 2 von 3 HP Pavilion G60-630US Power Button Replacement: Schritt 2, Bild 3 von 3
    • Carefully lift the battery out and away from the laptop.
  3. HP Pavilion G60-630US Power Button Replacement, Power Button: Schritt 3, Bild 1 von 3 HP Pavilion G60-630US Power Button Replacement, Power Button: Schritt 3, Bild 2 von 3 HP Pavilion G60-630US Power Button Replacement, Power Button: Schritt 3, Bild 3 von 3
    • Open the laptop normally.
    • Using your fingers (or a spudger if needed), loosen the silver cover surrounding the keyboard.
    • You will not be able to fully remove the keyboard/silver border all the way until the next step.
  4. HP Pavilion G60-630US Power Button Replacement: Schritt 4, Bild 1 von 3 HP Pavilion G60-630US Power Button Replacement: Schritt 4, Bild 2 von 3 HP Pavilion G60-630US Power Button Replacement: Schritt 4, Bild 3 von 3
    • Carefully place your hands underneath the now loosened keyboard and locate the ribbon keeping the keyboard connected to the laptop.
    • Locate the tabs keeping the ribbon in place.
    • Gently push the tabs inward to release the ribbon and to detach the keyboard.
    • Carefully remove the keyboard and place it off to the side.
    • The silver border and the power button will still be connected by a different ribbon.
  5. HP Pavilion G60-630US Power Button Replacement: Schritt 5, Bild 1 von 3 HP Pavilion G60-630US Power Button Replacement: Schritt 5, Bild 2 von 3 HP Pavilion G60-630US Power Button Replacement: Schritt 5, Bild 3 von 3
    • Locate the ribbon keeping the power button attached to the laptop.
    • Push the tab attaching the ribbon to the laptop to detach the silver border and the power button.
  6. HP Pavilion G60-630US Power Button Replacement: Schritt 6, Bild 1 von 3 HP Pavilion G60-630US Power Button Replacement: Schritt 6, Bild 2 von 3 HP Pavilion G60-630US Power Button Replacement: Schritt 6, Bild 3 von 3
    • If you are looking at this in the HP Pavilion G60-630US Screen Replacement Guide, ignore this step
    • Flip the silver border over to expose the underside of the power bar.
    • Unscrew the 4 screws keeping the power bar in place. Place the screws off the the side.
    • Carefully remove the power bar.
Abschluss
[deleted]
213 Reputation
2 Anleitungen geschrieben
Ein Kommentar
You have neglected to speak about removal of 5 screws from the bottom of the laptop! 3 inside the battery compartment and 2 on the corners of the laptop. Removal of these allow removal of the bezel and keyboard. Failure to remove these screws will cause damage to the keyboard and bezel!
Dave - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 31
Insgesamt: 2,201
