Was du brauchst
Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
To remove the laptop's screen, you will have to remove a total of four 7.25mm screws.
First, remove the two 7.25mm screws found in the upper right corner as shown.
Next, unscrew the two 7.25mm screws in the upper left corner of the laptop as shown.
Once all of the screws have been removed, gently lift the laptop's screen from the base of the computer.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
