Zum Hauptinhalt wechseln
HP Pavilion G7-2289wm Optical Drive Replacement
Was du brauchst
  1. HP Pavilion G7-2289wm Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Optical Drive Replacement, Optical Drive: Schritt 2, Bild 1 von 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Optical Drive Replacement: Schritt 3, Bild 1 von 2 HP Pavilion G7-2289wm Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
Abschluss
Ryson Smith
636 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 Mitglied von UMass Dartmouth, Team S8-G1, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 269
