Zum Hauptinhalt wechseln
HP Pavilion G7-2289wm Fan and Heat Sink Replacement
Was du brauchst
  1. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Optical Drive: Schritt 2, Bild 1 von 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 3, Bild 1 von 2 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 3, Bild 2 von 2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
  4. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Pull the edge of the service cover toward you to remove it.
  5. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the hard drive connector cable from the motherboard.
  6. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 6, Bild 1 von 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
  7. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Keyboard: Schritt 7, Bild 1 von 1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  8. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 8, Bild 1 von 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 8, Bild 2 von 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 8, Bild 3 von 3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
  9. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Fan and Heat Sink: Schritt 9, Bild 1 von 1
    • Remove the three screws that hold the keyboard palm rest in place using a Phillips #0 screwdriver.
    • Lift the palm rest up and out.
  10. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 10, Bild 1 von 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 10, Bild 2 von 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 10, Bild 3 von 3
    • Remove the wires attached under the keyboard.
  11. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 11, Bild 1 von 1
    • Pry open the bottom of the laptop by using the opening tool to open it up. Do this around the entire outer edge of the laptop.
  12. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 12, Bild 1 von 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 12, Bild 2 von 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 12, Bild 3 von 3
    • Remove the screw that holds the motherboard in place.
    • Remove the wires attached to the motherboard.
    • Unplug the laptop fan.
  13. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: Schritt 13, Bild 1 von 1
    • Remove the four screws that hold the fan and heat sink in place.
    • Remove the entire heat sink from the laptop.
Abschluss
Clayton LaBrecque
171 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 Mitglied von UMass Dartmouth, Team S8-G1, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 406
