Zum Hauptinhalt wechseln
HP Pavilion G7-2289wm Hard Drive Replacement
Was du brauchst
  1. HP Pavilion G7-2289wm Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Hard Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
Abschluss
Ryson Smith
636 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 Mitglied von UMass Dartmouth, Team S8-G1, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 208
