Zum Hauptinhalt wechseln
HP Pavilion G7-2289wm Keyboard Replacement
Was du brauchst
  1. HP Pavilion G7-2289wm Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  3. HP Pavilion G7-2289wm Keyboard Replacement: Schritt 3, Bild 1 von 3 HP Pavilion G7-2289wm Keyboard Replacement: Schritt 3, Bild 2 von 3 HP Pavilion G7-2289wm Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
Abschluss
Ryson Smith
636 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 Mitglied von UMass Dartmouth, Team S8-G1, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 189
