Zum Hauptinhalt wechseln
HP Pavilion G7-2289wm Touchpad Replacement
Was du brauchst
  1. HP Pavilion G7-2289wm Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Touchpad Replacement, Hard Drive: Schritt 2, Bild 1 von 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
  5. HP Pavilion G7-2289wm Touchpad Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  6. HP Pavilion G7-2289wm Touchpad Replacement: Schritt 6, Bild 1 von 3 HP Pavilion G7-2289wm Touchpad Replacement: Schritt 6, Bild 2 von 3 HP Pavilion G7-2289wm Touchpad Replacement: Schritt 6, Bild 3 von 3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
  7. HP Pavilion G7-2289wm Touchpad Replacement, Touchpad: Schritt 7, Bild 1 von 2 HP Pavilion G7-2289wm Touchpad Replacement, Touchpad: Schritt 7, Bild 2 von 2
    • Remove the wires attached to the button pad.
  8. HP Pavilion G7-2289wm Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Carefully lift and remove the button board.
    • Remove all screws from the bottom of the laptop.
Abschluss
Ryson Smith
636 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 Mitglied von UMass Dartmouth, Team S8-G1, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 605
