Zum Hauptinhalt wechseln
HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement
Was du brauchst
  1. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 2, Bild 1 von 2 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 2, Bild 2 von 2
    • Using the 1.5 Phillips #1 screwdriver, loosen the 7 screws.
  3. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 3, Bild 1 von 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 3, Bild 2 von 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 3, Bild 3 von 3
    • Insert the metal opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case.
    • Remove the back case.
    • When removing the back plate, use caution, removing slowly in order to not break the clips.
  4. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 4, Bild 1 von 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 4, Bild 2 von 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 4, Bild 3 von 3
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • With your fingers, push on the Ram stick until the metal arms are not holding the stick.
    • The RAM will pop up by a few millimeters up.
    • Remove it by pulling straight towards you and not a angle so you don't damage the socket.
  5. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 5, Bild 1 von 2 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: Schritt 5, Bild 2 von 2
    • Slide the RAM stick out from the memory module slot.
    • Repeat for the RAM stick located below. This computer had RAM in the slot below.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
CSU Los Angeles, Team 5-17, Kershman Fall 2023 Mitglied von CSU Los Angeles, Team 5-17, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G17
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 72
Insgesamt: 1,603
