Einleitung
If the laptop is overheating, it is possible that your fan is malfunctioning or needs to be cleaned. To replace, a replacement must be purchased and installed, while cleaning does not require a new fan. Follow this guide to clean or replace your computer fan.
  1. Locate the fan on the underside of the laptop.
    • Locate the fan on the underside of the laptop.
  2. Using a Phillips #1 screwdriver, remove the 4.5 mm screw securing the fan cover to the device.
    • Using a Phillips #1 screwdriver, remove the 4.5 mm screw securing the fan cover to the device.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Use a plastic spudger tool to free the cover.
    • Use a plastic spudger tool to free the cover.
    • The fan cover is extremely fragile and easy to break. Use caution during this step.
  5. Lift the fan up from the device. If you're cleaning the fan, stop at this step, and remove any build up. This can be done with tweezers and canned air. Disconnect the fan cable to fully remove the fan from the device.
    • Lift the fan up from the device.
    • If you're cleaning the fan, stop at this step, and remove any build up. This can be done with tweezers and canned air.
    • Disconnect the fan cable to fully remove the fan from the device.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Emily Hatstat
481 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
3 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 42
