Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
If your optical drive is not reading anything inserted, or is malfunctioning, it is possible that it is dirty or damaged due to electrical or physical circumstances. Once new optical drives are purchased, follow this guide to replace them.
  1. Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights. To remove this, pry it open with a spudger tool gently. It should pop out of place.
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. Remove the three 6mm screws using a Phillips #1 screwdriver. Once the screws are removed, the keyboard is free from the base of the laptop.
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. Disconnect the green ribbon cable using a plastic opening tool. Disconnect the green ribbon cable using a plastic opening tool.
    • Disconnect the green ribbon cable using a plastic opening tool.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver. Remove the top plastic covering from the base of the device.
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
  6. Use a plastic opening tool to disconnect both cable connectors gently. Use a plastic opening tool to disconnect both cable connectors gently.
    • Use a plastic opening tool to disconnect both cable connectors gently.
  7. Once these cables are disconnected, the optical drives can be found inside. This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
  8. The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive. Once freed, the CD/DVD combo drive should slide out and remove easily.
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
  9. The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive. Remove the floppy disc drive from the device.
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Lyndon Davis
124 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
3 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 3
Insgesamt: 57
