Einleitung
If you are using a sound card, video card, or network card in your laptop, they are inserted into the PCI slot. If they are malfunctioning, they need to be replaced or cleaned. Once the respective replacement is purchased, follow the guide to replace.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Locate the PCI port, it is next to the CD drive on the right side of the laptop.
    • Locate the PCI port, it is next to the CD drive on the right side of the laptop.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Use a spudger to open the button that disengages the card from the slot.
    • Use a spudger to open the button that disengages the card from the slot.
  4. Once popped out, press the button and the inserted PCI should eject and be removed easily. Our laptop contains a NetLINE PC Card that is a primitive Ethernet Network Adapter. This method works for all PCIs inserted to the PCI slot. Our laptop contains a NetLINE PC Card that is a primitive Ethernet Network Adapter. This method works for all PCIs inserted to the PCI slot.
    • Once popped out, press the button and the inserted PCI should eject and be removed easily.
    • Our laptop contains a NetLINE PC Card that is a primitive Ethernet Network Adapter. This method works for all PCIs inserted to the PCI slot.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Emily Hatstat
481 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
3 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 20
