Einleitung
If you are using a sound card, video card, or network card in your laptop, they are inserted into the PCI slot. If they are malfunctioning, they need to be replaced or cleaned. Once the respective replacement is purchased, follow the guide to replace.
Was du brauchst
Locate the PCI port, it is next to the CD drive on the right side of the laptop.
Once popped out, press the button and the inserted PCI should eject and be removed easily.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
